Help with Z9PE-D8 Build
dgollas
Hi, I am building monster Workstation and need some second opinions on components since I have read that there are some compatibility issues with the Z9PE-D8 WS motherboard.
Here are the specs:
Z9PE-D8 WS Motherboard
2x Intel Xeon E5-2687W
1x Nvidia Quadro K5000
1x Nvidia Tesla K20
64GB RAM (8 x 8GB Modules, probably Kingston ValueRAM KVR1333D3LD4R9S/8G)
Does the Z9PE-D8 still have issues with the Quadro K5000?
Is the Kingston RAM compatible? It's ECC and Registered, but you never know with server/workstation motherboards.
Thanks!
0 REPLIES 0
