Help, Rog Front Base in board Strick z390F, How do I connect it?
Jose_Maria
Cheers
I recently damaged an asus z290. To replace it I have thought of a Strik z390F. In my previous board I had the Rog Front Base connected in the connector of the "Rog Ext" board. The z390 no longer has this connector.
I would like to know if it is possible to connect the Rog Front Base to the z390 board in some way, because I love the front and it is a bummer not to be able to place it.
See if in this forum you can help me, because I have already sent two emails asking Asus about this topic and I do not receive a reply.
Thank you
AS185
Your motherboard has the AAFP connector. But I don't see anything for the ROG_EXT connector. You might have to consider buying a compatible motherboard for this device.
