**I'm not sure if this is the correct spot for this post, if not feel free to move it to it's right place**
The issue I'm having is one that is extremely weird and one I haven't had before on any previous system builds.
The pc can be running totally fine for month's, then one day I'll turn it off like usual and the next morning it wont boot. I've had the motherboard replaced once on warranty and it worked fine for about a year (Replaced 21/1/2015).
These issue's started roughly a month ago. I went out and bought a complete new set of part's, mobo,cpu etc. Before they got here i thought what the hell ill give it one last hurrah and it powered on no issue's at all, was lucky i could cancel the order and that was fine.
Then again Friday 18th it did the same thing. Working fine the day before, shutdown for the next next morning no boot. And again on the 25th.
-Step taken so far
When it happen's i have tried the cmos reset, backup battery is removed (permanently now)
Power supply work's when used with a power jump to turn it on, When its on the fan's and w/c pump's all work fine.
Tested with a spare power supply, Same issue it wont boot.
-What it does
When it doe's this, it has all motherboard light's on, power is there but just will not start on a case power or motherboard power button press. After it does this i unplug the main 24pin power bar and after 1-2 day's it will start just fine like nothing has happend to it.
-RIG
Asus Rampage IV Extreme
Corsair Dominator 16GB (4x4)
i7 3970x 3.5ghz (Stock, not overclocked)(w/c)
Various hard drives 2x ssd 2x 2tb 1x verloci raptor 1x 1tb
GTX Titan (w/c)
