Help Needed: My PC Boots at Full Fan Speed
CharlesMNeal
Hey, I'm somewhat new to PC gaming (I made a switch from Ps4), and I don't know much about gaming PCs.
Now the issue I'm currently having is whenever I boot up my PC, it starts at Full Fan Speed, and by this, I mean I have around 6x fan installed (excluding my 3x AIO fans) in my PC they start at this annoying noise level, now one more thing I would like add-in is that I am using the EK Elite AIO and all of my 9x fans are hooked up into the fan adapter that comes with this AIO.
Any Help Would Be Appreciated.
SmokeyKilla
I assume your using the pump AIO header, The AIO Pump header always operate at 100% on startup unless you change it in the bios.
