help me Asus zenith 2 extreme alpha
antonioosman
I have a motherboard zenith 2 extreme alpha with usb 3.2 Gen 2 connector which is on the board, and i would like to connect the usb c of the front of my BE QUIET Case Dark Base Pro 900 rev. 2 Full Tower, I connected the cable on the motherboard, I put a hd, the light comes on, you can hear the hd start, but the pc does not detect it, could you help me. Thanks
0 REPLIES 0
