Help Installing Max Turbo Boost 3 Asus MB Prime Deluxe II
lagauche
How do you install Max Turbo Boost 3.0?
Asus offers a version in their download/drivers sections. Here is the file structure:
https://drive.google.com/open?id=1QX67wtz9fAdZPMaMd9skXvHreQMzDeDS
If I run AsusSetup64.exe a window pops up saying driver installed and disappears, but it does not install the ITBM.exe GUI at all : /
I'm not going to install or use AI Suite III so I'm trying to figure out how to get Turbo Boost to install properly. Should I run AsusSetup.exe? I figured no since that's probably the 32bit installer? Confused..
Any help much appreciated.
Thanks!
6 REPLIES 6
MoKiChU
Level 40
Right click on "IntelNit.inf" > Install > Wait for the message "The operation completed successfully" or for restart request.
MoKiChU
Level 40
Here is the pure Intel version of Intel Turbo Boost Max 3.0 Technology Version 1.1.0.1005 WHQL : https://fichiers.touslesdrivers.com/57691/Intel%28R%29%20Turbo%20Max.zip
Install/Update process : Launch "setup.exe"
MoKiChU
Level 40
MoKiChU wrote:
Hey thanks so much. Mind if I ask (just to be cautious about grabbing drivers/software from someone) do you work for Asus or?
I've seen you post a lot of useful stuff on this forum so thought maybe you might work for Asus?
In fact, the drivers contained in it are exactly the same, only the installation package is different.
I'm not working for ASUS but actually I'd like that to be the case 😉
