Help I have ff code
znahcs75
I have a crosshair v formula z board it is give me a ff code it will boot. It I can't get any video and not hearing a beeps i can smell a burning
Snakeyes
Level 11
If you can smell burning, one of your hardware components (possibly motherboard) is toast (:-)). I would not turn on the PC anymore and immediately disconnect it from power before you damage any other components. Please check all the major components carefully before attempting to replace and rerun.
NAME THE SANDWICH: – White Bread, Lots of Baloney, Russian dressing and served with a small pickle.?
Intel Core i7 8700K @5.1 Stable Delidded
Asus Maximus X Code
16 GB
G skill TridentZ DDR4 ​4266 (PC4 34100)
Corsair HX1000i digital
EVGA 1070 GTX TiSuperclocked+
Samsung NVMe SSD 960 pro M. 2
Samsung 860 Pro
Watercooled with EK block radiator fans etc.
