Help choosing hard drive upgrade for g750
Lights_Out
So I just picked this laptop up for disgustingly cheap to use when I'm away from my main rig. Only problem I really have is with the hard drive. (That and the fact that I can't upgrade to windows 8.1 but that's another issue in itself)
Anyways, it comes with a 5400rpm hard drive and I find it horrendously slow, especially being that I'm use to my ssd and a 7200rpm hard drive which is the slowest hdd I'm used to using.
So my question is
1) should I keep the 5400rpm and get an ssd as a boot drive along with a couple of programs/games. If I go this option I'd probably only get 180-250gb drive.
or
2) Get a 7200rpm drive and just keep the 5400rpm for movies/music/documents/etc. If I go with the 7200rpm drive I'd probably go with 750gb or a 1 TB drive.
Only concern with going with an ssd is I won't be buying one with a lot of space and many programs/games will still have to go on that 5400rpm hdd. Opinions?
Antronman
7200rpm.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
kkn
Level 14
hit up he notebook section and ask around there.
if you want speed take a look at the SSD ( more pricy then HDD but mutch quicker )
the 5400 is made to been inside the laptops becouse they dont produce mutch heat compare to what a 7200 does.
