Thank you all for the information provided, especially kkn for is availability and various answers to my questions.
If you still have different opinions, please shared them… more brains work better than just one.
I’m becoming a fan of RoG, and this forum/site, it has a lot of useful information, and it will provide me the knowledge to better use the planned set up.
A quick run-down of what I’ll probably be getting:
Case -> Fractal Design Define R4
Board -> Asus Maximus VI Hero
CPU -> Intel Core i5 4670K
Mem -> Gskill Ripjaws X DDR3-1600MHz 2x8GB
HDD -> SSD Samsung 840 Pro 256GB
WC -> Swiftech H220
Fan -> 2x Noiseblocker BlackSilent Pro 140mm 1200RPM
For the cooling of the system, I’ll probably install the 2 Noiseblocker in the front, move the one that comes by default to the side panel, and mount the H220 on top of the case as an exhaust.
In this case, I’ll have a total of 2 intakes (2x140mm 1200RPM in the front, and a side 140mm 1000RPM) and 2 exhausts (140mm 1000RPM in the back, and the rad on the top). Hope this will suffice.
Ps. kkn, good advice for testing the components.
