Help / advice on mod needed
EnthusiastBuild
Level 12
Hi ROG'ers
Finally a dream came true with my first SLI system, but there goes my problem.
As you can see marked in the picture, the EVGA 780's are not equal to each other
with that specific part. So how could i hide this part, or mod the part on the first card to
look equal to the second one?
Cheers!
CORSAIR 900D
ASUS MAXIMUS VI FORMULA
INTEL I7 4770K @ 4.5 GHZ
CORSAIR DOMINATOR PLATINUM 16GB @ 2400MHZ
SLI EVGA GTX 780 SC ACX
SSD SYSTEM: CORSAIR FORCE GT 120GB
SSD APPS: CORSAIR FORCE GT 240 GB
HDD STORAGE: WD BLACK 2TB
CORSAIR AX860I PSU
CORSAIR H100I 4 x SP120 HP
11 REPLIES 11
kkn
Level 14
you can order backplates from evga online if you want.
as you see one have back plate and the other dont.
EnthusiastBuild
Level 12
Hey kkn
I know, they are currently not in stock for eu, but i still wanted to set my system up 🙂
Anyways I am not done with custom cables so no problem for me to have it like that for the moment.
But as you see on the picture the spots i marked, these are different plastic shrouds or w/e, i need to look them the same or hide them the same way.
Cheers
CORSAIR 900D
CORSAIR AX860I PSU
kkn
Level 14
i think you can buy from the us site.
or look at frozencpu and see if they have. and they too ship outside us.
EnthusiastBuild
Level 12
Thanks mate!
Any ideas to make the two plastic shrouds / covers make look alike or hiding them?
Upper one is white while lower one is black :mad:
Cheers
CORSAIR 900D
CORSAIR AX860I PSU
kkn
Level 14
from what i can see now i dont know what you are trying to point out ( on cell here so pic is so so ).
the black and white.
is it the washers or??
EnthusiastBuild
Level 12
There is a plastic cover / shroud which is behind the cooling fins, on the first card it is white, on the second card it is black.
Now I am hoping for suggestions or advice how to mod it that both look the same, because it ruins the look for me unfortunately :rolleyes:
Cheers
CORSAIR 900D
CORSAIR AX860I PSU
Myk_SilentShado
Level 15
I would suggest you check out Performance PC's in the UK, as they are closer the shipping charges should be lower for you 🙂
As for the plastic cover...just use permanent marker lol 😛
EnthusiastBuild
Level 12
Might aswell just wait until they are back at EVGA EU's stock since they told me it is stocked up soon but thanks guys!
Permanent marker was on my mind aswell, but, it would shine though, the plastic is matte on the card 😕 I want to solutionate this as perfect as possible!
Cheers
CORSAIR 900D
CORSAIR AX860I PSU
Myk_SilentShado
Level 15
Well there really is one choice and that is to return the one you don't want and get one that matches the other that you keep.
