headers advice please
Largestpower3
I have a ASUS STRIX-E Z490 motherboard, I'm trying to understand the headers better than what the directions say. I have A.D.D. and trying to understand the manual isn't my strongest subject. can someone give me advice, or a link to a youtube video that would be great! BTW I'm new to building computers...
GObonzo
there should be an image in the manual of the actual motherboard that has a description of each header:
24pin motherboard, 8pin power, USB, fans, RGB/aRGB, audio, front panel connections(power/reset/etc); all should be clearly labeled in this image with a page number associated that will better describe the actual header.
ASUS ROG Strix Z590-E Gaming | i7-11700K \ ASUS ROG Ryujin 360 | G.Skill TridentZ 3466 CL14 32GB | ASUS TUF RTX 3080 Ti | M2: 960GB \ SSDs: 5TB \ HDs: 16TB | Super Flower Leadex III 850w | Fractal Design Vector RS Blackout \ 5x be quiet! Silent Wings 3 140mm High-Speed PWM | Logitech G600 | Corsair K70 LUX RGB | Xbox One S Gamepad | Klipsch ProMedia 2.1 | Anker Soundcore Life Q20 | 34" Alienware AW3420DW \ 55" LG CX OLED | Windows 10 Pro x64
