GT-AX11000 Switch Connections
Wodyn_Gungnir
I have connected a TP-Link SG-108PE switch to my AX11000 router but I can not seem to get it to work I have the settings on the switch correct but for some reason the switch doesn't seem to work as should, I can access it through my PC but that is it. I can not find any information regarding the settings I need to change on the AX11000. Any advice welcome
0 REPLIES 0
