Graphics Card Suggestions?
asusrogboy
Hi guys, im planning to buy a graphics card yet i cant decide which to go for, if nvdia or amd. im looking for a graphic card that can support ultra high resolution gaming and 3 monitor or 42" led tv. Feel free to suggest guys. thanks!
9 REPLIES 9
Tenshi
I suggest Nvidia 600 series. If you have money of course.
i would suggest Nvidia 600 series too .. but dont get GPU lower than 660 TI .. for better performance
lenehan
This is a very subjective question. No one will able to recommend you unless you tell us what you prefer the Green Camp (Nvidia) or the Red camp (ATI).
For the green (6series)
For the ref (79XX) series.
Both camp still having some issue need to be fix (driver). Search around the forum/web before your final decision.
Change is the law of life. And those who look only to the past or present are certain to miss the future.
Sound_Solutions
Nvidia /ASUS Geforce GTX 680 TOP if funds allow.
mrwolf
Here check out his link for some up-to-date reviews of the latest cards on the market:
http://www.techradar.com/news/computing-components/graphics-cards/11-best-graphics-cards-in-the-worl...
PlaneName
If your running an intel motherbaord the best choice would be the Nvidia cards:
The GTX 680 will be the right choice, and make sure if your PSU is 600 watts or over.
If your running an AMD motherboard the ATI would be the chest choice:
The Ati 7970 will be the right choice, and make sure your PSU is 550 Watts or higher.
If you have a motherboard that support's sli you can buy 2 and make sure you have a PSU that is 800-1000 Watts.
Hope this helps.
Case: Antec 300 Mini Tower Motherboard: GA-Z68A-D3H-B3 (rev1.3) CPU: i5 2500k @ 4.5ghz Cooler: Hyper 212 EVO GPU: GIGABYTE GTX 560ti (950mhz) RAM: G.Skill 8 GB DDR3 @ 1600mhz PSU: Corsair CX 750 Driver: 320.00
Been building PC's for 8 Years! 😉
which is better gtx 580 or gtx 660 ti?
i bought already gtx 580 and it cost 500$ and the new gtx 660 ti only cost 300$... mistake decision?
The GTX 580 will still be the best choice because it has an 256-bit memory interface and it will be suitable for games such as Metro, Crysis and so on but the GTX 660ti will do much better performance on BF3, Crysis 2 and more but only by 3-5% percent increase that you will not notice between the two cards. The GTX 580 is still the best it can handle AA much more better than the 660ti because 660ti only has 192-bit memory interface. But it's still a powerful card which is more better and uses less power than the GTX 560ti if people is still on the GTX 560ti.
MTT
u could go withe the 670 it is the same as 580 and also it is the new generation 6xx
