graphic card woes with sli what driver
kevvy
hi chaps, right replaced my cards (asus gtx 670,s) with ROG 760 srtikers, and while playing farcry 4 ,i get a frame shadow over the playing frame, if you know what i mean, is this a driver problem ?? i,ve played the game with each card on its own and no problem, as soon as i sli them it happens, i,ve tried a few drivers, and the ones i have dont support sli on farcry 4, so is it the game or the drivers, all my other games work in sli with no probs, many thanks, 🙂
MOTHERBOARD : ROG CROSSHAIR V FORMULA... bios 1703
MONITOR : AOC 24 INCH 144HZ
PROCESSOR : AMD FX 8350 - 4.4 Ghz
RAM:CORSAIR : XMS 16 GIG 1760 hz
COOLING : DARK ROCK PRO 3
GRAPHICS : ROG GTX TWIN 760 STRIKERS IN SLI
PSU : CORSAIR HX750
X PREDATOR CASE : IN WHITE
Cruicial 256 Gig SSD OS
Cruicial 128 Gig SSD GAMING
FANS.2 Aerocool Dead Silence 140 mm Red top exhaust
2 Aerocool Dead Silence 140 mm Red 1 front intake1 rear exhaust1 Aerocool 200 mm front intake
WINDOWS 7 Ultimate 64 bit
10 REPLIES 10
Antronman
Level 11
Are you absolutely certain Vsync is enabled?
Are you using GeForce Experience to "optimize"?
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
hi, i have , i,ve tried both vsync on and off no diff, its weird when i first start the game and dont pause it will be perfect,then if i lets say go to the ammo then un pause then i get the frame shot of ammo shadow over the frame im playing, if i look upto the sky and pause and then un pause then the screen shot is clear, only cause the sky is clear if you see what i mean, so losing the will to play the game ,any ideas please ,many tnx
PSU : CORSAIR HX750
Are you using GeForce Experience at all?
try this:
Uninstall Geforce Experience (it causes way more problems then its worth);
In the Nvidia control panel go to Manage 3D settings
Click on the programs tab and select far cry 4; if its not listed then add and browse for the .exe that is listed on task manager while farcry4 is running (most likely farcry4.exe)
Under features, scroll down and set SLI rendering mode to Force alternate frame rendering 1.
See if that works for you;
simfreak101 wrote:
try this:
I can't tell if he is using GeForce Experience or not based on his post, but my issue is that when you use GeForce Experience to "optimize" your games, there is a very high likelihood that you will corrupt your game's config files.
If you are using GeForce Experience, uninstall it immediately, verify your game cache in Origin for Far Cry 4. If Origin finds something wrong, reinstall Far Cry 4.
kevvy
hi chaps, deleted GeForce Experience, and set the 3d setting set SLI rendering mode to Force alternate frame rendering 1 and no diff, (scratches head) , 😞
PSU : CORSAIR HX750
Antronman
Level 11
Try verifying the game cache through Origin. If an issue comes up, reinstall. It is very likely that GeForce Experience has corrupted your configuration files (for the game).
many tnx, i,ll try that tomorrow. 🙂
PSU : CORSAIR HX750
sectionate
Level 12
This is the best place for all your nvidia driver problems/issues -> https://forums.geforce.com/default/board/33/
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
