Gpu seating issues on my crosshair x870e hero
ROGn8fvs30938s1
So i just got a Crosshair x870e hero and installed my Gigabyte rtx 4090 gaming oc and i noticed after i screwed it to the case it had some vertical wiggle and it didnt make a distinct clicking sound when i installed it so i unscrewed it and tried to pull it straight out very gently just to see if it was locked in place and it did pull straight out with no damage or anything pretty easily. i took it out and examined the pcie slot and it looks perfectly normal theres nothing broken or anything im thinking it may just be the design of my gpu. i put it back in and tried to manually push the latch up all the way but it wouldnt lock idek if that how that works, anyway i didnt break anything i was just wondering if i should send my motherboard back or if its just my gpu design like i said it functions perfectly, i tested it in 3dmark and i got an above average score soo any comments and or advice on this would be great thanks.
https://imgur.com/a/BMhj93P
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
PhugoidEffect
Did you close the plastic latch at the end of the slot? If you did and it didn't offer any resistance it seems to be alright, especially considering it's working normally.
