GPU issue
vampireor
Hello , I recently bought the *“ Sapphire vega 56 pulse “ 8GB GPU , and i have the “ ASUS PRIME H270 “ motherboard* , So i gave my PC to the near PC shop , and he said that it goes inside but doesnt fit well , it will cause issues ,, Will it tho ? Is it not compatible or something ? Can someone check please ? , and if it do , can u give me a good Motherboard that fits with it and can handle the new ryzen CPU’s that will come out soon // and another cheap one ( doesnt need to fit with the ryzen 3rd gen , but fits with my card ) ,
Thanks !*
26 REPLIES 26
Jetxuan
Thanks !*
Don't buy a new MB.
xeromist
I merged these two threads and closed a 3rd thread here:
https://rog.asus.com/forum/showthread.php?110344-GPU-doesn%92t-fit
Please maintain *ONE* thread per topic so you aren't splitting up the discussion. If you have new information to add you can edit the first post and/or post updates.
panzlock
Level 12
Sapphire RX Vega 56 Pulse length: 282mm
NZXT H500i GPU clearance: 381mm
And in case you get a large CPU cooler you have 165mm of clearance.
You're good to go.
I'd like to deploy my troops in her country.
You're good to go.
Okay I built my new PC with same specs but a diff GPU ( the sapphire ) and a new case ( H500i NZXT ) so I'm done with building , it booted from the first try as this is my first time so here's my issue it won't have any display on the screen when I have my HDMI on the card but on my Intel it boots but my card has its light on but seems not to be functioning ,, so I have a Delco power supply non modular and I've seen on YT everyone uses a VGA for his card but I only had a PCI-E , but my card has 6 pins each but I only have 4*2 and a 2 so here's the deal I tried without the 2 it didn't work , what shall I do
Just one question : why did you came here for help, as far as I can tell you don't have any ROG parts, no do you intend to buy one (some)
It's an ASUS motherboard and ASUS closed the other forum so everyone comes here now.
You must have 2 8-pin power connectors to use that card. If the Delco PSU doesn't have the connectors you will need a new PSU.
