FX502VM M.2 slot
frostywolf
I recently got the FX502VM and it have a 1 TB drive , but I find it slow to boot up , so I want to upgrade it. There is an empty m.2 slot , but I want to know weather I can use it or not.
robaczek
What kind of HDD do you have there? Is it the old HDD style, or is it SDD or maybe something completely different? Regardless, if there is a port, you can use it 🙂 Just remember, for future reference, those ports usually render some of your SATA ports dormant, so best check the manual as in the process you may end up with the HDD non functioning, and you'll have to connect it to a different port.
CPU-i7 7700k @ 4.2Ghz
Graphics-Zotac Amp! Extreme 1080 Ti
Motherboard-Asus ROG Strix Z270F Gaming
Memory-16gb G.Skill Trident Z Series DDR4 3866MHz
Working hard at our web design studio in London - https://www.omdesign.co.uk/
