Front Panel LED Qusetion
mu5tang71
Ok.... I have a Thermaltake overseer RX-I Case...... I have been Painting it to match my motherbaord Maximus VI Formula... Notice that little BLUE light in the center that lights up the Thermaltake Logo..... Well I want to change it to RED to go with the theme of the board. It does not do anything but slowly pulses on/off. It is not any kind of indicator light. Just there for looks. but would look better RED!!
____________________________________________________________________________________________
I bought these RED LED's to try and replace the blue light. They are a a perfect match in physical size
but every time I hit it with power it blinks real fast a goes out.. appears to blow the bulb. I am sure I am getting to many volts in this bulb but no sure what voltage bulb to get to make this change work... Any help would be great
Asus Maximus VI Formula MB, Intel Core I7 4770K CPU, Thermaltake Overseer RX-II Case, H100 Corsair Cooler Push/Pull Config, 8GB (4 x 2GB) DDR3 1333 Ram, EVGA GeForce GTX 770 4GB Dual Classified w/ EVGA A w/ Backplate, EVGA SuperNOVA NEX750G Gold Power Supply, Window 7 Ultimate x64,
0 REPLIES 0
