Formula VI Question
stevieh
Hi there,
I have a now old Formula VI and have recently up graded to a pcie hard drive which I have managed to but into the top pciex1_1 slot and works fine would I be ok to put it into the slot under the x16 pcie slot 2 under my GPU in x16 slot 1 or would this cause the GPU to run at x8 I understand if it was a second GPU it would is this the same if it's a hard drive?
Thanks in advance for advise I don't know where else to ask.
Kind Regards,
Ste
4 REPLIES 4
Nate152
Hi stevieh
Welcome to the ROG forum.
Yes, installing your pcie hard drive into the 2nd pcie x16 slot would drop your gpu to x8.
Nate152 wrote:
Hi stevieh
That's a bad thing right? Thanks for the reply nate
Nate152
Nate152 wrote:
Not necessarily, running at x8 barely loses any performance.
Ok might try it thanks
