03-22-2013
05:37 AM
- last edited on
03-06-2024
09:41 PM
by
ROGBot
03-22-2013 07:03 AM
03-22-2013 11:03 AM
03-22-2013 11:28 AM
03-22-2013 11:53 AM
03-22-2013 12:09 PM
03-22-2013 12:06 PM
03-23-2013 07:15 AM
kkn wrote:
the board C posted does supord AM2 ( not AM3+ like the prosessors out now ( socket ) ) so its an old one in a way.
if you feel for it go for intel and the i5 3570K ( its unlocked for OC ) and go for samsung, 830 or 840 is up to you but the 840 is newer ( if im not mistaken )
are you gona expand whit a second graphic card in the future i would go for a 850/860W PSU, but if only a single one then go for the 650W ( gold/platinum version ) one.
asus or asrock, thats up to you and what futures yiu are interested in.
the ROG series are made for gamers and OC'ers in mind that want quality and menny options in bios for diffrent OC options. ( it may cost a bit but its a good one i think ).
03-23-2013 07:06 AM
