03-22-2013 05:42 AM - last edited on 03-06-2024 09:36 PM by ROGBot
03-22-2013 12:16 PM
03-23-2013 07:21 AM
03-23-2013 10:20 AM
03-23-2013 11:17 AM
03-23-2013 11:25 AM
Gryphus1153 wrote:
Thanks for the help with the graphics card and processor(I'm probably settling for an i5 3570k with a GTX670). Just a note I play planetside 2 alot and it's insanely CPU intensive. Even at 4.6GHz, the i7 2600k drops to 30fps in large battles. And I'm not sure how much the hypertheading will help in an i7.
03-23-2013 12:07 PM
Chino wrote:
Your GTX 560 TI is holding you back, not the i7 2600k. 😉 Gaming wise the i5 3570k is like 8%-10% faster than a i7 2600k in some games. In others, the difference is close to none. But if your fear is that your problem might have affected the i7 2600k and you wish to get a new CPU, then go ahead. 😛
03-23-2013 11:41 AM
