First gaming rig - Ivy bridge build advice
gamekraze_
CPU:Intel 3570K
Motherboard: Asus Maximus V formula
Cabinet:NZXT Switch 810 SE Matte Black
Cooler: CM Hyper 212+ EVO or NZXT Havik 140
Graphics Card: Gigabyte 670 Windforce
Hard Drive: 1TB Seagate
PSU: Corsair HX 650watts
Optical Drive:Asus DVD Drive
RAM: G.skill 2x4GB F3-12800CL9D-8GBXL
Please let me know if any changes are required. 🙂
5 REPLIES 5
HiVizMan
Level 40
From a cost/value/performance point of view have you looked at the 660Ti VGA's should save a bit of money and not make any major difference performance wise.
I would be playing games at 1080p nothing more than that, but if i did get a 30inch monitor would 660ti still be better than 670?
HiVizMan
Level 40
The size of your monitor is irrelevant, the resolution is important. And my friend the 660ti would do the job quite perfectly at 1080p. However if you have set your heart on the 670 then go for it. 🙂
Come on man everyone knows it's the size of the monitor. Sorry had too sounded funny when I read it
BHWAHHAAAHAA yeah size does count, but res counts even more. 😄
