First Gaming PC Build
Shavillone
Hi I'm currently building my first gaming PC and was wondering if i could get some advice on what graphics card i should get. I want to be able to play games like crysis 3, battlefield etc on maximum settings only using one monitor, I was thinking about getting a 7970 but not sure if its overkill or not. Also would like some feedback on the other components I've decided to get. Thanks
Asus Maximus V Formula
Thermaltake Armour Revo Case (Purchased)
Thermaltake Evo Blue 650w PSU (Purchased)
i5 3570k Processor
Corsairs H100i Cpu Cooler
Corsairs Dominator GT (2x4GB) RAM
Vertex 4 128gb SSD
(not sure about HDD or Dvd drive yet)
4 REPLIES 4
HiVizMan
Level 40
Really like what you have put together so far.
The 7970 is most certainly not overkill unless you will be using your system for word documents and emails 🙂
saipan
http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html
youll be fine.
| CM HAF X | i5 3750k | EVGA 770 ACX | ASUS Sabertooth Z77 MB | OCZ Vertex 4 120GB |
| WD 1TB Sata3 Caviar Black | Antec HC 850 | Creative Recon 3D
|Creative G500 5.1 | Razer Abyssus
lol101
Check out the HD7870 XT cost a lot less than HD7950 while have similar performance.
Here is a review
With the HD7870 it's only 2-way CFX and not 4-way CFX, not that you really need it, just letting you know since there is only 1 CFX connector
on the HD7870 vs 2 CFX connector on the HD7950.
For HDD a 7200 rpm drive to pair it with your SSD. Any additional HDD just grab them green drives for storage as they'll probably not be accessed that much.
For DVD burner, any of them is fine. Blu-Ray Burner however go with ones that support BDXL, it can support 100GB Blu-Ray media.
TenBlade
Level 11
I´ve read, that BF3 will use in excess of 2 gb gpu memory.
