First computer build
Elliven
Hey everyone my knowledge of computers is slowly growing so why not throw myself in the deep end and build my first. I’ve had help choosing which parts to purchase now I’m looking for any tips on how to start the build.
Im using the lian li dynamic evo xl case with
Ryzen 9900x3d
crosshair x870e apex
g skill trident z5 neo 24gb   x2
ryuo iv slc 360 AIO
Uni fan sl infinity x7
ddr5 1tb ssd
gigabyte GeForce 3080ti
hx750 power supply.
Power supply and gpu are in my current computer
any feedback would be appreciated
1 ACCEPTED SOLUTION
Accepted Solutions
Robot_Sonic
Level 11
Looking at the specs, this is a solid build. I didn't know that the Apex version is fully-loaded.
Robot_Sonic
Level 11
Nate152
Hello Elliven
Budget depending, I'd upgrade your power supply and graphics card.
Power supply - Amazon.com: ASUS ROG Strix 1000W Platinum (Fully Modular Power Supply, 80 Plus Platinum Certified, A...
Graphics Card - Amazon.com: ASUS NVIDIA GeForce RTX 5080 Graphic Card - 16 GB GDDR7-7680 x 4320-2.62 GHz Boost Clock...
As expensive as gpu's are, it might be worthwhile to hold out a couple months until the Super cards are released.
mrsimon0007
Awesome setup! Take your time with cable management, double-check motherboard standoffs, and watch a build guide for your case. That rig’s gonna look and run amazing!
