First build help
FireLion
Good afternoon , I am looking into building a gaming computer in 3 months time , I would appreciate any input on what parts to get with a budget of roughly £2,500(GBP) give or take a few hundred , excluding peripherals. I have been having a search around and I have come up with
Case - Obsidian Series® 900D Super Tower Case
Motherboard - Maximus VII Hero
Cpu - Intel core I7-4790/4790k
Video card - EVGA Gtx 780 Ti
Ram - corsair vengeance 16/32 GB
SSD - Samsung EVO (Thanks Antronman)
HDD - Seagate Barracuda 1TB 7200RPM 64MB Cache.(Thanks Antronman)
Power supply - Not decided
All input is welcomed and appreciated , Thank you all in advance.
31 REPLIES 31
FireLion
Hmmm , i guess i am going to have to do a bit of studying as i don't really understand the differences , all i am wanting really is an ultimate gaming / 3d rendering comp , that can handle 3 1440p monitors , without a problem in high/ultra settings lol
Arne_Saknussemm
Level 40
Hmm well I think the "problem" is your monitor. The Swift will come with a DP connection so you will need one GPU per monitor for this setup I think. I say will because this is not currently possible. At the moment Gsync does not work surround even with TRI SLI connected one DP monitor to each card though Nvidia say they are working on support for this now.
With triple SLI you would have to go for a board that can give you at least a x8 slot for each GPU....Maximus VI Extreme for example does x8x16x8....or RIVE, RIVBE etc do x16x16x8
Of course monitors without Gsync you can set up surround on SLI or tri SLI without worrying about one card connected to one monitor. 3x 1080p monitors on SLI for example...or 3x1440 on triple Tis or Titans...
