first build advice
adicc
this is my first build need some advice on what i have picked out if all looks good and what kinda fans and rads i should use also i have a caselabs th10a
http://ca.pcpartpicker.com/p/KPQQcf
10 REPLIES 10
kkn
Level 14
looi at my second last post about rad and fans.
you have 45mm rad and you have the 60mm rad and you have the monster 80mm rad.
sit down and draw up a scetch on how you wil set it ut.
that way you will se how menny fittings you need and angles or straight ones.
buy a couple extra to be on safe side.
tubing get extra in case of wrong cutting.
