first build advice
adicc
this is my first build need some advice on what i have picked out if all looks good and what kinda fans and rads i should use also i have a caselabs th10a
http://ca.pcpartpicker.com/p/KPQQcf
10 REPLIES 10
MeanMachine
I can't see nothing wrong with this build asicc and Good Luck.
Just be very careful when installing the CPU, and make sure to very carefully tighten cooler support brackets evenly, as with that socket it is easy to bend the pins on the CPU.
Have you chosen a case to put it all into yet?
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
kkn
Level 14
case is a caselab.
memory. do 2x8 kit if its cheeper.
and that hdd will make noice when it spinns up.
are you going to switch out the fans in the case or the cooler?
the h105 comes whit 2 fans.
adicc
will i plain on putting Scythe Gentle Typhoon in the case and a custom water cooling loop
kkn
Level 14
fann: go for mmH2o in stead of cfm, this is becouse of the preshure a fan can push tru a radiator.
1.x mmh2o and upwards is best.
radiator: 2x 120mm ( 240 radiator ) fan slot for each OC'd component in the loop.
so if you for example is going to put CPU and 1 GPU under water, you would need 4x 120 fan slot whit radiator space, 1 480mm radiator or 1x 360 radiator + 1x 120mm radiator or 2x 240mm radiators.
you need pump, you need tubing, you need fittings, you have to have the case for it all to fit inside.
is it the caselab magnum case you are going to buy?
adicc
Yea it's the case labs th10a and I'm going a little over board with this build I hope to do dual loops an using 480 rads can't remember if thst the size
kkn
Level 14
480 = 4x 120mm fan slot.
one loop for CPU and one for GPU/GPU's?
adicc
Yup one loop for CPU and sli gpu
so what kinda rads and fitting should i get like what company is good
adicc
could someone till me what kinda fittings i should get and what rads and fans
