Fans
Silver_Wolf
Hey Guys,
I am looking for some fans to up the cooling in my system and would like some advice. I am from Australia and the price doesn't matter. My case is an Aerocool X Predator and what I am looking to put in is 6 140mm fans, I am not concerned about how loud or quiet they are I just want good airflow. I am currently looking at the Bitfenix Spectre Pros however they currently don't have any out with Green LEDs which I would like 4 of to go on the clear window on the side of the case. If anyone has any suggestions of other fans to look at by all means post them up and lI'll take a look.
Kind Regards, Silver Wolf
16 REPLIES 16
Zka17 wrote:
If I would be you, I would go with the Aerocools...
i agree with this guy!
im using 140mm Aerocool Devil Red Shark Fans and its doin' great! blows a lot of air and it is quiet... 🙂
R7-3700X | ROG STRIX B550-F WIFI | Noctua NH-D15s | 2x16Gb TUF VULCAN 3600Mhz | 4 X 1TB WD Caviar Blue, 2TB Caviar Green | Palit GTX 1070Ti | SEASONIC 850W FOCUS GOLD | NZXT Phantom White | ASUS VG278QR-J / ASUS VX239H
Karmageddon
I might look at using These 140mm corsair fans for your side panel as they excel in pulling air through with no restrictions like 0on side panels, and then These 120mm corsair fans for your drive bays as they excel in restricted environments like pulling air through drive cages.
They might not glow green, but you can pick up some LED strips for cheap to give the same effect. They excel in moving air and staying fairly quiet so IMO i would take them over the others
My Build
I7 3730k at 4.7 ghz
H100
16gb Corsair Dominator GT RAM at 1866 mhz
2 x Asus GTX DCU2 670's overclocked at 1258 mhz
1 x 1tb Storage Drive
1 x 2 tb Game Drive
1x 60 gb SSD Boot Drive
CoolerMaster HAF X
Kingwin Lazer 1000w
So for side mounted fans I am better off with a higher airflow rather than a higher static pressure right? In which case the best option would be http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_316_848&products_id... however for best air pressure http://www.pccasegear.com/index.php?main_page=product_info&cPath=9_1232&products_id=19135 takes it out so which stat is best or am I looking for a mix of the two or something else entirely?
Karmageddon
You want a fan with high static pressure that has to move air through a radiator, hard drive trays, or a thick case panel. when threes no restrictions like on a side panel, or the back exhaust on a case, a fan that has higher airflow is better because it excels at pulling air from all around it.
You are better off going with a mix of fans as each excels depending where you place them in your case
My Build
I7 3730k at 4.7 ghz
H100
1 x 2 tb Game Drive
CoolerMaster HAF X
Kingwin Lazer 1000w
Ok so for reference purposes my case is pictured here http://www.hardwarelook.com/images/uploads/REVIEWS/ENCLOSURES/Aero_Cool_XPredator/large/xpredator_si... now for the side panel I would want fans with the best airflow right?
Thank you for the explanation Karmageddon 🙂 I had pretty much figured as much but still trying to wrap my head around cooling lol my old case never had options to add extra fans so I am now trying to get my head around what I actually need but I think I pretty much have that worked out now just need to confirm the above.
Karmageddon
Correct, for your side pannel you want fans with the best airflow as there is extreamly little to no restrictions for your fans. Keep in mind that your fans might be a bit loud, so you may want to pick up a fan controller for them if noise is an issue for you
My Build
I7 3730k at 4.7 ghz
H100
1 x 2 tb Game Drive
CoolerMaster HAF X
Kingwin Lazer 1000w
Silver_Wolf
Thanks for the heads up. My case has 2 fan controllers built in so I plan to make use of them for this 🙂
