Fan and temp issues. Help?
Dcm210
So this is my build.
Mobo: Asus ROG Crosshair VII Hero ATX AM4 Motherboard
CPU: AMD Ryzen 7 2700X 3.7 GHz 8-Core Processor
CPU cooler: NZXT Kraken M22 120mm liquid cooler
RAM: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 CL16 Memory
Case: Antec P280
Ok so I got two Antec RGB fans on the top as intake. I got two thermaltake static pressure fans on the radiator (one on each side as outtake)
Just doing the basic things the fans start speeding up. The temp in bios says about 65 Celsius. Anyway I can adjust this? Maybe this is a bug due to it being an AMD CPU. I know AMD Cpus run hotter.
0 REPLIES 0
