Jay ... Welcome ... unless the minute background sounds ... and voice is important in your
game play ... or you are also obsesive about music ... the CrossHair V has great sound as is.
the rest ... optional to taste as mentioned above ... TV ? ..... um .... no. unless its the only one.
for that there are tv/monitors .... plug your 'puter into your 60" .... it has a tuner ... (said light heartedly)
the icy thing ... a cooler drive ... cant hurt none.
best quote of the thread .... " if you're actually going to use it."
like a car friend ... dont buy a blue one .. if you wanted a red one .. make YOU happy.
Best of Luck and enjoy.c.
