01-13-2020
05:48 AM
- last edited on
03-05-2024
08:26 PM
by
ROGBot
01-22-2020 09:24 PM
01-23-2020 06:48 PM
neonitron wrote:
Are you using a monitor with the desktop PC that supports 144hz or higher? (EDIT: Just saw you did specify that it is a 144hz monitor - the below notes still apply)
Also, are you using a DVI-D cable? I know in my particular situation, I had to use either DVI-D or DisplayLink cable - NOT HDMI. Then I needed to ensure that in Windows and in my NVidia settings it was recognizing the 144hz monitor (ensure that everything was set to 144hz).
Then in Rocket League, I had to specifically specify in the game settings to max out at 144 fps. By default it is capped at 60 fps. After that, it was running nicely.
I am using a GTX 1070 with an AMD Ryzen 5 2600x, Asus prime as320i-K, 8 GB of DDR4 RAM, and steam game files are installed on an SSHD.
01-23-2020 10:42 AM
