EKWB Monoblock installation on rmapage 5 E 10 board. -help pls
animalmom
Hi - I am trying to install the monolock on my rampage 5 E 10 board.
I am evidently supposed to punch holes in the motherboard. There are supposed to be "stickers" *covering the holes *
Well I tried with light pressure and it appears there are more than stickers and I'm scared to proceed.*
There is a lot of resistance.
Any advice?
62567*
62568*
animalmom
Hi, I solved this, I removed the screws on the bracket , and then could punch trhough. *
Best regards,
J*
