Dual rtx 4090 mobo
Grimmbeaver
Hello Experts!
id like to build a gaming/hashing rig with dual RTX 4090s.  Which would be my best option for a motherboard that has the space to accommodate two rtx4090s with PCIe x16 slots and with an intel gen 14 i9 processor?
thanks in advance!
Nate152
Hello Grimmbeaver
The ROG Maximus Z790 Dark Hero is one that supports SLI, it looks to have good slot spacing too.
It's also designed for Intel 14th Gen cpu's.
The RTX 4090 doesn’t support SLI, I thought that technology was abandoned.  I’ll check out the motherboard you mentioned!  Thanks for responding so quickly.
Nate152
You're welcome
You are correct, there is no SLI support for the RTX 4000 series gpu's.
Another one would be the ROG Maximus Z790 Apex Encore, it has only two memory slots but it should do better with memory clocking.
