Does my PC boot properly? It takes 20s to POST.
xychangli
The QLEDs glow orange-red-orange-red-white-green, the POST takes 20 seconds then the ROG logo shows up. Is this the normal way for the LEDs to glow?
The mobo is ROG Strix X470-I, CPU is R7 2700X, DRAM is Corsair Vengeance RGB 16GB and GPU is GTX 1080 Ti.
Retired
Not applicable
Well, everything seem's to be in order, in terms of booting. The motherboard check's the cpu, hdd and ram as according to your Qleds. As long as you get a boot and everything works just fine, no need to worry 🙂
