DOCP settings problem with Asus ROG STRIX B450-F GAMING
Jozweerd
MY problem is that when I turn docp on in bios and 3200 mhz my pc does not boot but turns off 3 times and turns it on again and then bios resets my ram to 2133 mhz, i can set to 2933 but not above that. my ram is corsair vengeance lpx 3200 2x8gb and i have the latest bios firmware Version 3103
my pc setup is
AMD Ryzen 3400g
Asus ROG STRIX B450-F GAMING ATX AM4
Corsair Vengeance LPX 16 GB (2 x 8 GB)
Jozweerd
I have my ram installed in a2 b2 i also tried different a1 a2, and b1 b2 and a1 b1 but i cant get the speed working at 3200 MHz. So whats wrong?
Poorly constructed bios updates is the answer - I don't have your motherboard but on my crosshair hero VIII there is only one bios out of the last 6 that I can DCOP with specified RAM speed and timing - so you are not alone. You might want upgrade/downgrade your bios to test. Cheers!
RedSector73
Level 12
my pc setup is
AMD Ryzen 3400g
Corsair Vengeance has version number on it. Check it than match against QVL.... don't match, welcome to why you dont buy corsair vengance LPX for Ryzen systems.
It is total loot box cheap crap.
