10-03-2020 04:14 AM - last edited 3 weeks ago by ROGBot
10-03-2020 01:26 PM
10-03-2020 03:51 PM
xeromist wrote:
If you lift the card while installing the screws that can help with some sag. You generally don't need a support unless you are moving the machine around a lot, but it can't hurt and it might look better if you care about that.
