directstorage and bios settings
rolly123
I have the rog maximus x hero and I have the samsung 970 evo plus 2T m.2 on it as PCIE.
I'm trying to figure out what settings in this bios can achieve "directstorage". Right now it is set as "intel rst optane..." . Should it be on "SCHI" instead. Right now in xbox game bar in settings it show c:\ as non-NVMe drive.  I don't do RAID.
achugh
Level 14
Hi @rolly123 Intel RST Optane is meant for SATA drives. This is why you are not seeing the higher NVMe speeds.
If you can, do a fresh Windows install with VMD disabled in BIOS and during Windows installation DO NOT load any Intel drivers. Just install Windows. This will setup Windows properly with your drive being detected as NVMe.
Disclaimer: I am not an ASUS support person so my information may be incomplete. Always follow official documentation and material provided by ASUS representatives.
INTEL i9-14900K / CORSAIR VENGEANCE RGB 192GB (4x48GB) 5200 CAS38 / ROG Z790 DARK HERO / ROG TUF GAMING RTX 4090 OC / ProArt PA-602 Case / SEASONIC PRIME TX-1300 ATX 3.0 / CORSAIR MP700 PRO 2TB PCIe Gen5 / CRUCIAL T500 2TB PCIe Gen4 / EIZO CG2700X
