01-27-2025 03:00 PM
I have a b550-e board and updated the bios before swapping my CPU’s. I went from a ryzen 7 3700 to a ryzen 9 5950x and get the D6 code instantly on boot. When I swap back to the 3700 CPU it runs fine. HELP PLEASE AND THANKS!
01-27-2025 03:40 PM
Hello Tdow226
Code D6 is usually a gpu related error, strange you get D6 after swapping cpu's.
Try this:
With your pc off and the power supply cable unplugged:
After swapping cpu's, clear the cmos by shorting the two pins of the Clear CMOS header.
Then see if she fires up.
01-28-2025 05:49 AM
Just tried that and still getting the D6 code instantly it works fine with the 3700, once I swap cpu, no go. Very frustrated at this point
3 weeks ago
When you have the 3700 cpu installed, try reverting all of the BIOS settings to default. 5950X is available from BIOS update 1004.
