Crosshair VI Very high default voltage
DeReMaR
Hi, I've noticed that i have very high voltahe on cpu (no OC - just from box). It's equaling from 1.417-1.48. Is it normal. Underload it's near 1.2. Must i stay on auto voltage mode or set it to offset mode with minus? (Ryzen 5 1600x). Or can you link a guide for "x" processors?
DeReMaR
Moreover, found, that it's not a hardware issue, it's BIOS thing, waiting for fix
Gottcha! 😉 It's def XFR and PB for 1600x volt. Nothing to worry 'bout. This high states will handle cpu for few sec than it goes down to normal values ~1.2. Op
