Hi Guyz….
Please could anyone suggest a way around installing 2 ASUS Vega 64 cards onto a crosshair VI Hero
I know it's probably overkill and not necessary however....
I have installed them into PCIE 1 and 2 at the moment as there is no way to fit the card into slot 3
Due to the USB Headers there , the card just wont fit..
I'm a little concerned that the 2 cards are too close to each other in slots 1 & 2 .
Any suggestions would be appreciated , eg: some sort of adapter plate ?
Thanks in advance for your answers / suggestions
Regards Gazza_65
