Crosshair VI Hero AM4 rear i/o shield
justinwotis
Hello All,
I am looking for some advice here regarding my board. I just recieved the board (Crosshair VI Hero) from Newegg, bought it from an open box deal. Saved a bunch of money and the board is in fine working order. My issue is that it didn't come with a rear i/o shield. I knew that might happen as I have bought open box motherboards in the past and had this happen. I am asking for advice on how to obtain a replacement. I have tried ebay, google, and even emailed Asus directly. Asus just responded by sending me a link to their authorized vendor and said "good luck." But no such luck. Any ideas?
Nate152
Hi Justinwotis
Unfortunately that's a chance you take when buying open box items. I'd use it without the I/O shield for now and keep checking around until you find one.
Found on on ebay finally.
