CROSSHAIR V FORMULA-Z won't POST after Win10 Standby?
Bannor101
Hi all,
So built this PC back in Jan 2017, left it running the other day, came back after a few hours and it was shutdown. Assumed Win10 standby mode. Since then cannot get the thing to POST. Have now stripped it back to just CPU, Heatsink, 1 DIMM and PSU. It actually POSTed and showed Q code 36 once, but that is not repeatable. Start and Reset buttons are lit so board is powered. CPU and board power connectors are only PSU cables connected.
I've even tried to USB flash the BIOS in case that was corrupted but even that fails (red BIOS light stops flashing and stays lit which I understand indicates failure?).
I've even bought a replacement board but the exact same situation occurs, so I'm now left wondering if the CPU is dodgy, but it's only a couple of months old and I've not even overclocked anything!!
Any ideas would be much appreciated!
Cheers.
Build details:
Asus CROSSHAIR V FORMULA-Z 990X Socket AM3+ 8 Channel Audio ATX Motherboard
AMD FX 9590 4.7GHz Socket AM3+ 8MB L3 Cache Retail Boxed Processor
Cooler Master Hyper 212x 4 Heatpipe 1x 120 Pwm Fan Tower Cpu Cooler
Corsair Vengeance Pro Gold 16GB Kit (2x8GB) DDR3 2400MHz DIMM Memory
ASUS AMD Radeon RX480 8GB GDDR5 Gaming Graphics Card- STRIX-RX480-O8G-GAMING
Samsung 850 EVO 500GB 2.5inch SSD
Bannor101
Removed m/b from case and managed to get a POST, stopped at Qcode 66, switched off and back to same situation...
Any thoughts welcome.*
