Crossfire help
immaturegizzmoe
I have a Matrix 7970 card, it works great and Im not ready to purchase a larger card yet, however I would like to get some more fps out of my current games. I found someone with a 7970 card for $90.00, will this card crossfire with mine since there both 7970's or do i have to have another Matrix?
7 REPLIES 7
Nate152
Dr__Zchivago
Level 12
+1 Nate. Additionally, and this isn't critical; but, for the sake of performance, it's not a bad idea to make sure the model numbers match too. Those cards should end with a "V278" or something like that.
Z
EDIT: I say that only because some different versions (but, same manufacturer) have clock speed differences - the two cards in X-Fire will run at the lower speeds, unless the lower speed GPU/VRAM is OCed to match the higher one.
Thanks everyone, I appreciate the info
sectionate
Level 12
you might have issues if the gpus have a different bios
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
Nate152
Hi guys
Different bios's on the gpu's shouldn't be a problem, my 680's have different bios's and run just fine.
Nate152 wrote:
Hi guys
AMD and NVIDIA = 2 diffrent cards manufacturer's nate.
elesde
Why should there be any problems with different bios versions? Even with 2 exact same models the chances are slim that the bios versions are identical unless you purchased them at the same time.
As Z said there might be some performance left on the table if you get a second card with lower clocks than the Matrix. Plus on some older games frametimes can be really bad due to missing frame pacing for Crossfire on DX9.
