Cpu problems
Lmjrv
I have an overclocked i5-8600k paired with a rog strix vega 64 but the cpu is bottlenecking, what would be a good cpu to pair with the vega 64 within the lga 1151 socket?
Nate152
Hello Lmjrv
The best cpu you can get for socket 1151 is the i9-9900k. Check your motherboard specs to see if it supports Intel 9th Gen cpu's.
You can check the bottlenecker to see how you fare.
Bottleneck Calculator | PC Builds (pc-builds.com)
