08-08-2024 06:46 AM
Hi everyone. I installed a Rog Strix x670e-e gaming wifi. When you turn on the power supply, should the LED of the two 8-pin connectors also light up? Because it doesn't turn on for me. With the power supply turned on, the aura of the motherboard and the red LED of the 16-pin Nvidia video card light up, however if I press the power button on the case the computer does not start.
08-08-2024 03:54 PM - edited 08-08-2024 04:50 PM
Hello FrancoV78
A list of your pc specs can be helpful.
Double check all your cable connections, if you have any questions where they go, feel free to ask.
Check you have the PWRSW cable connected to the system panel header properly.
09-07-2024 11:07 PM
Hi @FrancoV78 is your problem resolved? Did you try pressing the START button on your board?
