09-21-202008:07 AM - last edited on 03-05-202407:40 PM by ROGBot
I have a cpu fan error and i am using a kraken nzxt z73 aio pump. I have checked my plugins several times, i can't find anything wrong on that end. My bios menu always pops up when i turn on my new computer, but i can't find anything wrong! I am new to building computers and this is my first build if there is any advice i can get that would be great!
Check your manual for this...there will be a CPU fan header on the board that seems not to be plugged to anything.
Maybe that the Kraken fans are running from a different header...or from molex or something like that.
If you are happy that your Kraken fans are working...then you can disable CPU fan monitoring on Monitor tab in BIOS (scroll down to CPU and select disable monitoring)
