In my computer, I have 3 Fractal Design case fans and 1 be quiet CPU cooler, and my motherboard is the Maximus IX Hero (See system specs for full details)
The problem is that when i turn on my computer, none of the fans spin. I have gone through 2 of these motherboards (both used and purchased off ebay) and have gotten the same CPU fan error message each time. Becasue all of my fans worked on my previous ASUS motherboard, i know that none of them are defective.
Here is what ive tried so far:
- Tested 5 different fans on each of the headers
- Reset the CMOS via back panel button and removing the CMOS battery for at least 30 seconds
- Updated the BIOS
- Checked to make sure each of the fans are plugged into the correct headers
- Disabled Q-Fan Control for each of the fans
- Set CPU fan speed lower limit to "ignore"
- Ignored fan speed monitoring on all of my fans
If i "save and restart" from the bios, i can actually log onto the desktop and use my computer with no issues, but i havent actually used it normally for fear that it will overheat.
DO YOU HAVE ANY SUGGESTIONS????
