CPU compatibility?
FPS_Exorcist
Is the Asus ROG Maximus 11 Hero (Black ops 4 edition) compatible with the Core i9 9900k processor (with or without a bios update?)
Nate152
Hi FPS_Exorcist,
Welcome to the ROG forum !
The ROG Maximus XI Hero Black Ops 4 edition supports 8th and 9th generation cpu's. You'll likely have to update to the latest bios for the board to recognize the i9-9900k. Updating the bios is easily done with the bios flashback feature.
All you need is power to the board and a usb flash drive with the latest bios which you can download from the ASUS Support Center.
