Corsair Ax 860
Giannis996
sorry for starting a thread only for a small question but can an ax860 run 2 gtx titans and the maximus vi extreme with all the psu connectors meaning 24pin 8 + 4 pin and 6pin (optional) without any problem?? the system will only get 2 hdd and 2 ssd's and 1 msata on the micro pci combo 2.0
Project Name: System Specs:
Motherboard: Asus Rampage IV Black Edition
Prossesor: Intel Core i7 4820k
Graphic Card: Asus GTX Titan x2
*Power Supply: Cooler Master V850
Ram: 32Gb Corsair Dominator Platinum 2133Mhz
Case: Corsair Obsidian 750D
SSD: 2x Samsung Evo 250Gb Raid 0
HDD: 2x Seagate Baraccuda 2TB
HiVizMan
Level 40
If the Titans are going to be clocked above stock I would want a larger PSU. They are very volt hungry when you OC them. Arne has two also, I will ask him to comment as well.
Giannis996
i wont overclock them... i will also buy the Asus GTX titans if that helps cause i was between asus and EVGA but evga preoverclocks them...
HiVizMan
Level 40
You should be fine in that case.
