Connecting watercooling to MB
Crof
Hey guys.
So i finalt installed my ek hfx 360 wc kit. I've now gotten to the part where i have to connect all the cables and i started wondering. I have 3 fans in the rad and only the cpu + cpu opt slot? What Would be suggested in this case? Dó i Need to connect anything there and so forth. Thanks in advance
- Chris
Arne_Saknussemm
Level 40
If they are normal 120mm fans you can run 2 from one header with no worries whatsoever...the headers are 1A each.....so if you have a Y splitter you can run 2 off the CPU and 1 off the CPU OPT
What's the amperage on the fans? You could use either a three-way or two two-way splitters and connect all the to cpu header.
x99-pro/3.1 | i7-5820k | 16gb gskils 3000 | Nvidia gtx 980 ti | 512gb SM950 Pro | Predator 360 AIO | ASUS PA248Q | Seasonic Platnium 1000w
